Replacing Lift Pump. Need Advice.
1/4 tank fill up
Waiting period for synthetic ATF?
I think the lift pump has finally given in. I like the idea of replacing it with something other than OEM, but I am afraid to because I am not sure how it will hold up to everyday use. Maybe when it has been tested more. What happens if I go down to the dealer and buy a new one? Do they hold up better now than the one I have on there now? Are they available from Cummins for less then from DC? I need to make a decision quick. The truck is parked in the garage until I fix.
98. 5 3500 QC 4x4, Driftwood/Mist Grey, 5 spd, 3. 54, 19. 5 Alcoa's, 245/70-19. 5 Michelin's, Ranchhand front bumper, Ranchhand rear bumper, Ranchhand toolbox, "Scotty Air", TST PowerMax2, Autometer Gauges, Centerforce clutch, Upgraded fuel lines (JRE and Aeroquip), MagHytec Diff Cover, PacBrake
Hey Jeff,
Didn't someone post something about seeing the stock pump in Summit's catalog? I think that was in HVAC's post about the Holley.
1999 2500 QC 4X4 LB Auto 4. 10LS, Driftwood, CD player with Steering Wheel Controls, Power Driver's Seat, 275HP Injectors, PowerEdge, K&N Air Filter, Brushguard, Spray-in Liner, 285/75R16 BFG AT KO's, Nerf Bars, Black Diamond Plate Deep Well Tool Box, Mopar flat antispray guards (front and back)
2000 Yamaha Big Bear 400 4X4
NRA Member
TX... it was a Carter that a member used , said it was the exact same thing that dodge uses..... JB
99 Quad,Long bed,4x4, SLT,Auto,K&N,Mobil Super Delvac 1300,fuel line up-grade from lift pump to filter and from filter to injection pump, Suncoast coverter,BD valve body and pressure-loc,Mag-Hytec trans pan,Amsoil ATF-4,Auto meter Ultra lite gauges:Boost,EGT,Fuel Pressure,Trans Temp, "true" Jet-Hot Coated 5 inch exhaust from turbo to tail pipe(over the axle)Borla shoot-out muffler,DD stage 3 injectors and boost module,HX-40 16cm,here and waiting to be installed, Next Jet-hot my ATS exhaust manifold and turbo housing, and special thanx to rob for swaying me on a 4 wire Blue Box(incoming)
Jeff, I you want a OEM replacement Lift Pump, go to a Cummins Dealer, The lift pump from them is about a $120. 00. From Dodge its around $390. 00.
Doug.
1998. 5,2500,ISB,Auto,CC,4x4,White Sport,275hp Injectors,240hp to the Ground,BD Pressure Lock,16x8 Eagles,295 BFG's,2. 5" Skyjacker Lift,Stockland Seibring Shell.
26ft Weekend Warrior.
1973 R/S Z28 Camaro.
1989 Jeep Cherokee.
427ci 585hp L88 Crate Motor, Still in the Crate!.
The Carter from Summitt would work for me. I have the JRE 1/2" fuel line kit so my lift pump is drilled and tapped for 3/8 pipe. All I would need to do is get a new fitting for the output side of the pump and I'm in business. Thanks for all the help.
Animal, I just found the pump in the Jeg's catalog for the same price. The one you told me about is 14-16 psi and requires a regulator. The one that is smaller is 6-8 psi and does not require a regulator. Will the larger one work without providing too much pressure and what about the regulator?
I hope you can get a Carter that will perform better then the stocker. Let us know how the Carter performs. The Holley 12-815 costs $139 for comparison.
Hey Nowel, what do you know about this pressure thing I mentioned above. The Carter I am looking at says it requires a pressure regulator but the others from the same series do not require a regulator. I am worried about the pressure being to high.
Jeff,
You will not need a regulator, that is only needed for carburator use.
The High pressure pump is the one I recommend.
Ted Jannetty
Ted Jannetty, Owner President Jannetty Racing Enterprises Inc.
97 3500 4x4 club cab 5spd. RED, JRE stage 3 power kit, JRE 4" exhaust
JRE 1/2 inch fuel system, Cummins 370 hp injectors, Prime loc,
Cummins chrome kit, US Gear 20% over drive, 3. 54 posi, Autometer
gauges, boost, and Pyrometer, BD exhaust brake.
97 Ski-Doo 670 turbocharged
99 Honda Forman 450 ES
Thanks for the input guys. I ordered the high pressure Carter. Should have it first thing in the morning. I will post some results when I get it in.
Great Jeff... am looking forward to your results... JB
