Another fuel hose suggestion
GKarpen said:
I replaced all my steel lines, both supply 3/8" and retrun 5/16" with marine grade rubber hose from Mr. Bob's Dist. . I have been using it for 18 months now and everything is great. Get rid of those bango's.
Lots of good ideas here gentlemen for replacing or upgrading the fuel lines on our trucks - here's another.
Our local industrial supply house, Top Line Products of Temecula, provided me with a very affordable solution, which is perhaps as suitable as the marine grade hose. It's Weatherhead / Eaton 250 working PSI hose, with push-on Barb-Tite fittings. I looked up the specs on the mfr site and they say it's suitable for diesel fuel, water and air hose, and if the application required fittings, the push on fittings make it user serviceable - no crimping required.
In this case, I found my leak, but it wasn't the DC stock fuel hoses (I'm sure those are almost ready to pop !), but the Prime-Loc remote fuel filter system hoses that reach from the stock fuel filter location / adaptor to the remote mount (2 hoses @ 24" ea), that had developed a pin-hole leak.
This hose they supplied sure looks as strong or stronger than the stock Prime-Loc lines and it was easy to cut to length and push the end fittings on. I'll try to report back after some time on the integrity these lines show. The other nice thing was cost, this hose is just . 96 / ft retail and the fittings a buck or two each.
I'll surely consider using this line to replace the DC fuel & return lines ASAP if these two perform well.
Here's the URL for those hoses & fittings FYI:
http://hydraulics.eaton.com/products/pdfs/W-HYOV-MC002-E01_Hose_Low_Pressure.pdf
Regards, David B.
