Replacing Transfer Case Control Module (TCCM)
Cheap, Easy lift pump pressure gauge
2005 5.9 auto crank no start
EStadler
Has anyone had to replace a TCCM on a 2004.5 Ram, NV5600 trans and SRW.
There is a notice on my center council "service 4WD" but there is no check engine code.
A local shop was able to clear codes and get the transfer case back into 2H from where it was stuck in 4H.
The selector knob on the dash would not work although the indicator light did show it was in 4H. When I left the shop all was well. No codes and the selector knob worked correctly. Now I get the "service 4wh" notice.
Been any similar problems out there and if so, what was the best repair.
Thanks
Ed Stadler 2004.5 HO Laramie Quad cab, Long Bed, SRW NV 5600 manual w/ 4wdr
After market stuff- Cool air intake, Bilsteans, Pacbrake, MagHytec diff covers (both ends) EGT & Boost compo gauges.
