Great timing, as I just removed mine today. It is definitely a job but is not bad if you go slow and do things in order. I just drove up on some two-by blocks and raised the front end about 6 inches, plenty of room to work. The most difficult part is that dang cross-member. It is tapered and is wider at the top and I found that by using a dead blow hammer and tapping it back to the flatter part of the frame it was only really hard to get out rather than really really hard. The other thing was the removal of the flexplate to convertor bolts. I finally figured out that they were accesed through a cover plate under the cooler, near the plug for the barring tool. I used a large screwdriver to rotate the ring gear and took them out one at a time. There was loc-tite on them so it was a chore. I took my floor jack and used a pipe flange and a short 3/4" pipe nipple to replace the metal cup and bolted a couple pieces of plywood to the flange making a flat platform to rest the trans on. I worked great and I was able to remove it alone. Some guys remove the transmission with the transfer case attatched but I found the T-case to come out failry easy after that cross member was out. I also am taking advantage of the situation and painting my drive lines while they are out. Take your time and remove all the cooler lines also, it doesn't take that much time and they can be drained and cleaned. They cross under the bellhousing and you would have to pull the trans back about 6 inches to clear them, I didn't want to risk damage so I removed them. Between climbing out to get tools and wiping up that fluid it took me about 4 hours. If I did it again I could do it in two, but let's hope I don't have to!
