My 96 has started developing a vibration only when in 4x4. I have checked axle shaft u-joints and ball joints and narrowed it down to the front driveshaft. After I removed the shaft, there appears to be a bind spot in the CV joint (transfer case) end. I bought new u-joints at NAPA and started tearing into it tonight. It appears that I am going to have a driveshaft shop replace the u-joints after seeing how this is built. Am I correct on this or is there a way to drop out the u-joints that sit between the end of the driveshaft and the cross-shaft? Thanks.
