This morning I discovered a leak at my water pump. Initial discovery appears to be a steady drip from the bottom of the water pump. I suppose the gasket could've gone bad but either way she has 133,000 on the original pump so figure I'll replace it and the gasket regardless. I've seen some conflicting information about which coolant to run on a 2010. I plan on doing a full coolant flush at the same time so I would like to know the correct coolant to run. I really have no desire to pay dealer prices for their inflated product unless it is absolutely necessary. I also read somewhere, can't seem to find it now, where I should replace the fan clutch at the same time. Any thoughts on this?
Thanks in advance for any and all help.
