I've had the E-Brake by Jacobs on my 2000 Ram for 7+ years & 130,000+ miles, all trouble free. While hauling my TT several hundred miles from home recently I noticed that I had a dead pedal for about five seconds after being off the throttle for several seconds. The "dead" period ended with black smoke & skyrocketing EGT's. This led me to check the operation of my exhaust brake. What I found was that it was taking the exhaust brake about five seconds to totally release. I switched off the exhaust brake and drove without any problems.
I had time today to fix the brake. The problem was caused by a clogged sintered bronze breather filter vent mounted on the side of the vacuum solenoid assembly. The vent allows air to enter the system and release the brake when the vacuum solenoid switches to the brake off position. The almost totally clogged vent allowed air to enter the system very slowly. I removed the vent, cleaned the vent with lacquer thinner, and reinstalled the vent. Problem solved.
The exhaust brake butterfly now opens quickly, likely much faster than it has for a long time.
I'm adding a sintered bronze breather filter vent (McMaster-Carr - $1. 21) to my tool box. It can be changed in minutes.
•• Click to Enlarge ••
