Details here: TDR Privileges
Thanks for your help on this as "NAV Settings" was the hint I needed. Interestingly, my RER radio is different and the 2010 Manual is wrong. I just went out and tried the directions above (which are consistent with the manual I found on the Dodge website) and they don't work. There is no "NAV Settings" button on my screen after I hit the NAV hard key.
I finally found it though so for others that may be having the same problem:
Press MENU hard key
Touch the NAV Settings soft key
Touch the Set Default State soft key to chose your state
Whoever the brilliant engineer was that moved it from the NAV key must have been smokin' a little too much.
