resetting "Low Coolant" dash message
Transmission service
G56 - South Bend Clutch (Stage 1) Installed Cost?
cricha
2017 3500 - got a "low Coolant" dash message while doing flush outs on the cooling system. how do you reset this? there arent any error codes set. THANKS!!
No reset. Crude on the magnet that slides up and down next to the sensor. I'm fighting the same issue. Need to drain down the coolant, remove tank and clean the magnet. Just keep check on the levels and your good!
