Restarting problem after fuel filter change
Valve Adjustment
Best alignment specs for 2wd?
Well I had an interesting experience yesterday. I changed out my fuel filter, following all procedures meticulously, and my truck would not start. This went on for about an hour and a half. I took the filter off after re-draining the strainer, added fresh fuel, and re-primed the system (yes, the lift pump functioned perfectly) but the truck would not start. Finally, I cranked it over and pumped the pedal and voila!!, the truck kicked over like nothing ever happened. My question is twofold: Have any of you had this problem? Why should the pedal being pumped make a difference on these newer vehicles? I was under the impression that fuel delivery during startup was specifically controlled by the ECM. Things are fine and I didn't crank the truck to long for fear of my fuel pump grenading on me for lack of lubrication. I also noticed gel like material in the bottom of my strainer which I had never seen before. It has been cold here in Georgia (unusually so for these parts) so I attribute it to the weather and possible the fuel. Any and all insights are welcome.
John
1999 Dodge Ram 3500 Quad Cab 5 spd; 4:10 LSD rear; Mag-Hytec diff. cover; US Gear EGT and Boost gauges.
Cummins Whup Ass, don't leave home without it
John, have you ever checked your fuel pressure at the outlet side of your filter canister? It is possible you have a marginal lift pump.
If that checks out OK, try this next time: Bump the starter without starting the engine and let the lift pump run through its long cycle. Do this twice and it should fire right up. When I replace my filter I reinstall the lid with the chamber only 2/3 full of fuel. I prime it by bumping the starter then it lights off instantly with no smoke or sputter.
Vaughn
Sounds like you might have had an airlock in the system. Usually when that happens, you have to "crack" injector lines to clear it out.
2001 HO 6 spd 2500, 4. 10 LSD, Towing Package, Electric Brakes, SPA EGT/Boost Gauges, Fog Lights, Real Backup Lights, Molded Running Boards
I had problems too. I bump primed the system three times. Then tried to start it. The engine turned over for about 4-5 seconds before it started. It sputtered for 2 seconds then ran fine from then on. Any suggestions on what I might have done wrong??
Thanks for the replies. I suspected an airlock, but have no way of knowing for sure. Vaughn, I did follow the procedure you recommended in your post and have always done so. Maybe the stars weren't aligned correctly for this change. Who knows. I have not checked the fuel pressure at the outlet, but I'm going to do that this weekend. I want to add a gauge so as to be able to monitor the fuel pressure at all times. Any suggestions on where to get a gauge.
John
