After spending the last few months getting everything put together I finally had time to dyno the BD twins with Stage 1 CP3. I went to the dyno that I have been going to since I owned my truck so all my runs are saved. I also tried various combinations of TST 03 twins program, Smarty, and MP8 pressure box. The results were surprising in that I think the big 90 HP injectors I have need totally different box combinations than what others with stock injectors need to do. All numbers reported below are UNCORRECTED ACTUALS on a DynoJet. No correction factor BS voodoo applied! I think Meridian, Idaho is at 4200 feet elevation.
The best numbers I got with a stock CP3, single SPS 62 turbo, and 90 HP 3-flow injectors were 539 HP/1000 TQ with the TST on 4x2. Any TST power or torque level higher lost power due to the rail running dry. Details HERE
Baseline Comparison
This was done with fuel boxes off to compare the stock CP3 and single turbo SPS 62 to the Stage 1 CP3 and BD twins.
Stock CP3, SPS 62: 362 HP/663 TQ
Stage 1 CP3, twins: 349 HP/634 TQ
As you can see I lost 17 HP with the twins baseline. I believe what is happening is that with minimal modifications the twins take some HP to "drive" them. Also, this time I had 285 versus the stock 265 tires on.
TST With or Without MP8
All of these runs had low EGT and the smoke cleared up really quick.
TST 3x1, MP8 0%: 439 HP/871 TQ
TST 4x1, MP8 0%: 494 HP/951 TQ (SPS 62, stock CP3 was 522 HP/1061 TQ)
TST 5x1, MP8 0%: 546 HP/1057 TQ (rail pressure ~ 24K; EGT ~1000*)
TST 6x1, MP8 0%: 4XX HP/9XX TQ (lost rail pressure)
TST 5x1, MP8 30%: 596 HP/1124 TQ (rail pressure ~24K; EGT ~1200*)
TST 6x1, MP8 30%: 540 HP, 904 TQ (lost rail pressure)
As you can see, the modded CP3 allowed me to gain one more TST level. Further, when the modded CP3 was then controlled by a pressure box further gains can be realized at the same max TST level. In all I think I can say that the CP3 has allowed for at least 50 more HP to be realized - possibly more if I could get the twins spooled on the dyno better. The modded CP3 has virtually eliminated the infamous 2200 rpm dip on the dynos when the rail lost pressure. Tomeygun also observed this on his dynos.
One thing I am beginning to find out is that while these BD twins are very quick spool on the street, they are less than this on a dyno due to no load. I think on the street, I would easily be pushing low 6XX HP. Still low smoke and EGT at these fueling levels are amazing as compared to the single turbo, which had the pyro pegged on the top rpm range.
Smarty on 60 HP No Timing with TST and MP8
I was expecting big numbers from this combo, but sadly this did not happen. The Smarty runs were a bit hotter, smoked a bit more, and cleared up less than without the Smarty.
Smarty 60 HP no timing, TST 3x1, MP8 0%: 524 HP/1102 TQ
Smarty 60 HP no timing, TST 4x1, MP8 30%: 565 HP/1103 TQ
Smarty 60 HP no timing, TST 0x0, MP8 0%: 439 HP/862 TQ
Smarty 60 HP no timing, TST 4x1, MP8 0%: 567 HP/1104 TQ
Smarty 60 HP no timing, TST 5x1, MP8 0%: 494 HP/1015 TQ
On the TST 4x1 runs, the results were the same with or without MP8 pressure!
However, one has got to love that flat torque curve!
Smarty on 120 HP Timing Program + MP8 Pressure Box
Again, really flat, wide torque curves. At MP8 40%, the rail pressure high level alarm just started going off too.
Smarty 120 HP timing, MP8 0%: 524 HP/973 TQ
Smarty 120 HP timing, MP8 30%: 541 HP/1011 TQ
Smarty 120 HP timing, MP8 40%: 567 HP/1062 TQ (high rail pressure alarm)
Comments
1) While my rail is capped (Floor-It rail cap), I will only use up to 40% MP8 setting to prevent excessive rail pressure.
2) I'm disappointed in the Smarty. While it drastically improves driveability in town it appears to not work to well on my truck in terms of max power before the rail runs dry. When the Smarty was on, my truck EGT was also hotter and the exhaust was smokier than without the Smarty over the entire rpm range.
3) I did have an exhaust leak in the engine compartment by virtue of the small soot clouds, Maybe this affected turbo spool up or maybe not - not sure because I couldn't exactly tell where the leak was coming from.
4) I think I am done modding. :-laf
I'm happy with the numbers for a 305/555. I just don't want to go down the more expensive modding road for a while. Bigger fish to fry right now. If I had to try something different it would probably be slightly smaller injectors to get more TST tuneability back.
5) I just would have wished I could have got the twins spooled more on the dyno like they do on the street. Maybe my numbers would have been more than what I got. I clearly has some more room as witnessed by the EGT levels.
Anyhow, I hope this post helps you guys out...
Also, just like to say thanks to AK Ram, Jeff K, and cquestad from DTR for all the tuning advice the've given me through various PM and emails. cquestad was there when I dynoed a lot and provided the extra set of eyes to watch the gauges and take notes.
Baseline Comparison
Comments
