Well, I finally resolved the cab noise, resonance, and droning problem with the Banks 4" exhaust system. I promised to let other TDR members know the results of this, as many of you provided suggestions that eventually led to this solution.
As I've said in past posts, Banks is having considerable complaints on the noise of this system primarily from Dodge Cummins owners and Chevy Duramax owners, the common theme being the inline 6 cylinder diesel.
So, after checking several locations for pricing, the best price was from www.exhaustproslinc.com. I purchased the 30" SS body Magna-Flow for $179. 00, and the 14" SS body Magna-Flow for $104. 00, all plus shipping, plus one extra 4" clamp.
A young lady by the name of Angela was a tremendous help on this problem and in selecting the correct components.
On the Quadcab Banks systems, you have a small 24" piece of extender pipe just forward of the Banks muffler. That was removed and a 5" piece was cut off to serve as the bridge piece between the two MF mufflers. After removing the burrs on all edges, we slid the 14" MF on, then the 5" bridge piece, then the 30" MF, and finally the tailpipe.
It went on incredibly easy, no heat required.
Absolutely no modifications had to be made anywhere, the whole thing fit like a glove.
I took it out on the road, and sunk my foot deeply into the floor, all the way to 80 mph. I could not believe the results. The interior cab noise was no louder than the OEM exhaust system, I was stunned.
There is no drone, no resonance, no roar, no nothing except a steady low volume sound that never increases in volume beyond a certain point. The results were far better than I had hoped. We can now turn the radio back on, hold quiet interior conversations at normal levels, and most importantly, when using a lot of power, there is no more cab rumble or resonance anymore. It truly is now comfortable to drive again, only this time with a full-flow 4" system front to back.
I highly recommend this solution to anyone else with this problem. I would also recommend the purchase of the 14" MF unit to add ahead of the Banks muffler for reduced noise and resonance for those folks wanting to keep the Banks unit.
But anyhow guys, I am happier than a pig in s--- with the results.
Oo.
Robert
Oo.
Robert
