I’ve had Amsoil ATF in the transmission since I installed the BD valve body, Pressure Lock and Pro-Torque TC in August of 2000 at just under 12K. I drop the pan from time to time and replace the filter each time, and I reinstall the Amsoil ATF. (I'm pretty careful about making sure it's clean. ) I’m at almost 63K now and I’m considering just going back to ATF +3. As easy as it is to change fluid (and filter), I was thinking I might as well go back and see if that would have any “improving” effect on the shudder I sometimes feel at 65ish when the transmission hasn’t completely warmed up. (I’ve experienced this for quite some time. ) Other than the TC lock-up engaging too soon in OD, I've experienced no other transmission problems.
If I go back to ATF +3, must I remove ALL the Amsoil when doing so? Or can I just remove the 11 quarts or so that don’t come out of the lines and TC, and do a couple changes at, say, 10K intervals until it all works itself out? Or should I just keep the Amsoil, or maybe just replace it? ‘Appreciate your opinions.
