Reverse light feed
Hats off to PML Transmission & Rear End Covers
Stock or Aftermarket front brakes?
I'm installing back up lights on my 06 ram.
Does anyone know where i can tap in for the reverse light feed up front and not have to go to the tail lights?
Thanks
If you have a seven pin trailer connector, use the middle pin. There's plenty of power there to run a couple of 55W lamps without using a relay and I believe it's fused seperately.
I didn't want to tap in back there b/c i need to put it on a switch as well as turn on everytime it goes into Reverse. anyone where i can find it the cab or engine compartment?
How about using the backup lamp switch? The wire could run into the cab via the shifter hole. Or do you have an automatic?
-Ryan
