Engine/Transmission (1994 - 1998) Revised Cummins T-stat numbers?
Engine/Transmission (1998.5 - 2002) Great deal on '02 leftover?
Engine/Transmission (1994 - 1998) Successfully rebuilt my first turbo
Need part numbers for the new CUMMINS REVISED thermostats
1995 12v'er in 180*:______________________
1998. 5 24 v'er in 180*:_____________________
1998. 5 24 v'er in 190*:_____________________
I called a local Cummins shop to get them and they wanted the engine numbers to look them up.
I have mine, but my Dad's rig is in Wyoming and I want to get it for him without him knowing (otherwise, he'll want to pay for it).
Any help you be appreciated. Thanks.
Is the revised one a non cycling t stat?
There is a part # listed in one of the TDR issues. Will have to look back a few years.
I have a non cycling t stat. Works good.
Ben: I don't know what "new Cummins Revised thermostat" means. I have a number that was the latest number on 24 JUL 2001. This may or may not be the latest revision. The number I have is Cummins P/N 3934373 equal to DC P/N 3928499.
I thought I remembered more recent information on the thermostat than my 2001 date but do not find anything in my part number listing.
I will be interested in the other responses as I need to change my thermostat. It wants to stick closed sometimes. The current thermostat is a NAPA changed out in Mar 2000. The Napa P/N was 370-180 and cost $9. 00. This thermostat does cycle up and down.
I tried the new revised thermostat it stopped the cycling but ran way too cold. Ended up with the 190° Stant stat from Napa for $9 also. Still cycles but not as bad as the stock and at least warms ups
Non-cycling T-stat at last!
Originally posted by Jammar9082
... The number I have is Cummins P/N 3934373 equal to DC P/N 3928499.
Jammar9082, Thanks for the information.
NEW T-STAT WORKS GREAT :). Very consistent 170* unloaded and does not fluctuate ANY! And, the cab heater still "cooks". Couldn't be happier :D
I called Cummins with the 3928499 number and they said it was their most current number for the t-stat. Neither 1-800-Diesels, or Cummins Intermountain, in SLC, could verify any "re-design", but they did confirm the 180* setting. The 180* is supposed to respond slower - thus slowing down the hugh rush of cold radiator coolant into the block (and the constant temp cycling that it causes). The result is a more constant coolant temp.
Parts - all Genuine Cummins Parts and Numbers from a local Cummins repair shop. These are NOT Chrysler part numbers):
T-stat - 3928499
(Date on box: 20-Nov-02, Origin: MX, Genuine Cummins Parts) - $18. 99.
O-Ring Gasket - 3925466 (Radiator side) - $0. 75.
Housing Gasket - 3927305 (sleeve-style, thicker, with recessed groove on one end) - $2. 88.
True, our Cummins engine tends to "tollerate" the temp fluctuations with the older, stock t-stats AND many members have quite high miles with their original stat... BUT for under $25 why tempt fate with your head gasket? This is IMO, an ounce of prevention.
I wish I had replaced my stock stat much earlier. Have yet to pull a load with it, but trust it will perform equally well.
Hmmmm... .
I was just thinking about this tonight. I'm in the same situation Bill was. I replaced my good old "swinging" stat when I should have replaced the fan clutch.
Where on the temp guage did your improved Cummins stat run, Bill?
Anyone have an old "swinger" they want to send me?
I probably won't ever use my old one again, but I'm going to toss it in my bed box (with my spare fuel filter) in case I need it when I'm on the road.
Also, one more part to have around in case a traveling TDR Member needs it after hours and they break down in my neck of the woods.
Someone else have one they could send?
My improved Cummins stat ran a steady 140-150 in the winter, never gave it a chance in warmer weather. The stock stat cycled between 140-190. My $9 Stant cycles between 170-190 year round. These numbers are assuming the lower hash mark is 140 as the only number on my gauge is 190.
Originally posted by illflem
My improved Cummins stat ran a steady 140-150 in the winter...
At 150*, I would have pulled it out too - not near warm enough.
My new one runs at a solid, steady 170*. Cab heater works great.
Perhaps (apparently) you got a defective one. :(
Mine does year 'round. With the radiator covered and 35+ degree weather, it'll go a little higher but not much. I'll go get the NAPA one tomorrow. Thanks Bill!
