REVO economy settings?
Southbend Clutch
FASS, AirDog, or carry a spare?
Ok the REVO has been out for a while, so what settings have you guys found to give the most economy and least smoke?
I have a 2005, auto, stock except 285/75 tires. Tried REVO level 3, timing 4, everything else default, 14 mpg loaded (12' overall height with the equipment in the bed) averaged about 65mph, too much smoke. On return leg (750 miles each way) of the trip tried level 1, stock TQ, timing 4, rest default and got 20 mpg empty. Ave 70 mph with some rain. Nice software, but still too much smoke compared to stock. Would more rail pressure (with less duration I assume) reduce the smoke?
Odd thing was the REVO “stock” software smoked heavily during low rpm acceleration (in tow haul mode). Don’t remember the truck ever doing that before. Rechecked that the “stock” program was in the truck. Uploaded older software into Smarty and then loaded older stock program into truck. On a short run it did not smoke like with the REVO “stock” program. Weird.
I've been running SW#3, TM=2 (mild), Timing=3 (aftermarket inj), RP=1 (stock), WG=Disabled. It is a little less smoky on the lower RPM end but less then the higher timing settings. When pulling the 30' 5th wheel @ 67-70 MPH on mostly level ground I got 13. 2 MPG. Mild throttle @ < 10 lbs of boost gave me a slight amount of smoke. Above 10 lbs under heavy throttle the smoke would clear up. With the cruise set @ 67 MPH pyro read 800* and boost was 8-9 PSI with no smoke. Poke the go pedal a bit and I would get some smoke/haze - mash it and I'd get a brief puff and the it would clear.
I think the characteristics are a little different with the after market turbo as it doesn't build boost quite as fast as stock.
