I have an opportunity to buy a set of 6. 75" wide Rickson's from a guy at work - just the wheels, no tires. His truck is a '98, mine is a '00 both are 2500 4wds. I talked to Matt at Rickson and the '99/earlier wheels have 1. 5" more offset than the '00/later according to him. His comment was they will fit but may require fender flares and obviously will load the wheel bearings differently than the 'proper' offset wheels.
Is anybody running the '99/earlier Rickson's on a '00/later truck? How does it look and can you provide pics? I'm going to try and borrow one of the wheels for a test fit but I don't think the tires are still on the rim.
Has anybody had a front wheel bearing fail due to using the larger offset wheels?
What was changed in '00 to require the huge difference in offset? I know the front brakes were significantly changed but I don't about anything else - can't remember... .
Brian
Brian
