Hi Guys,
As fair warning, this is going to be a bit of a long post, but my truck has some serious issues that are beyond my ability to troubleshoot. I doubt anyone will remember, but a couple of months ago I posted about my '89 with a slow idle and loosing power. After replacing the lift pump and putting a gauge on the fuel supply, I decided that it must be the injection pump dieing and ordered a new one. I've been fighting this thing ever since and still don't have it running right. I'm about at my wits end and need some ideas. History is as follows:
- Truck starts idleing slower and loosing power over about 2 weeks. No longer smokes at WOT and boost falls from 19 psi to 12 psi. Still starts instantly and runs smoothly on all six, just acts like it's not getting full fuel. Fuel pressure gauge after the filter shows 5 psi at idle so decide to replace injection pump.
- While I'm waiting for the injection pump, I order new injectors (Bosch 190's from Pier's).
- All the parts arrive and I install, following exactly my Cummins manual. Truck starts and runs, but now idles at 500 rpm and has ZERO power. As in I can't even get the boost gauge to budge. It still revs freely with no load, just no power under load. NO smoke of any color from the tailpipe.
- I call the fuel injection shop and attempt to troubleshoot over the phone. After checking all connections, etc. He has my try turning in the smoke screw. That does nothing. I then trying turning in the power screw one turn. That instantly woke the truck up! Idle was at 800 rpm and could get about 17 psi of boost. Had quite a bit of turbo lag however.
- Now that I have it running, I notice that the pump is leaking fuel. Tracked it down to a hairline crack in the housing. great... So I called the shop and they sent me a new one under the warranty.
- Installed new pump. Once again idle was at 600 rpm, but I did have some power, it just wasn't very good and would get bluish white smoke from the tailpipe when reving. Playing with the timing did nothing, but once again adjusting the fuel screw brought the idle up to 800 rpm. Power however was still kinda lousy and could only get about 12 psi of boost. The engine also didn't sound "quite right", sort of a hard rattle noise at idle. Very long turbo lag and the transmission wouldn't shift until I hit redline at 2500 rpm.
- So today I tried changing the injectors back to the ones I pulled out of it. Noted that the 190's were already sooted up real bad. Doing this restored the beloved cummins clatter and brought my idle up to 950 rpm. I can now get about 17 psi of boost, but power is still lousy and it builds boost slowly. Under WOT excelleration, it will slowly build boost to about 13 psi, then sit at 2500 rpm for several seconds while the boost drops off. Then it will upshift to 2nd and repeat. Once I hit 3rd, I can get 17 psi. wierd, no? No smoke visible of any color.
- It's obvious that something is still wrong with the truck. It's certainly not driveable in its current state. I'm completely stumped and very tired of having my head in the engine compartment. What the heck is the deal with this thing? Any ideas?
Isaac
Isaac
