So i have an 04 qqlb, and an 08 mega,
the 08 sits 1.75 lower in the front, and is a rougher ride over uneven roads. look as though it hits the bump stops rather often.
No before you say shocks both truck have the exact same 4600's on them.
these trucks should ride about the same, both have the same frame lengths. the 04 is an auto, the 08 is a stick.
even still i can't find a reason the 08 would ride so much harsher, same tire pressure, same size tires.
why does the 08 site 1.5-1.75 lower in the front?
I even purchased some ones older front coil springs, as comparing the ones on the 08 to the 04's the 08's were a lot smaller in diameter, the new ones i got used are the same as my 04's, from the outside looking in, i did not pull the coils from my 04 to compare. the thicker coils helped the ride some but it's still far from the 04's. i'm thinking i might have to get a 2" coil to make the 08 ride like the 04.
speed bumps, parking lot entrances all seem to bottom the front of the 08 out, and same speed on the 04 is smooth as silk.
i will add the 08 uses less boost to drive down the road at 70 as well, it's around 2-4 where the 04 is 6-10.
ideas?
ideas?
