Ride Leveling a 2wd
AIRSEPT
Screen for Grill/Radiator?
I've always wondered why later model Rams are set up with a "nose-down" attitude compared to older models. This looks even goofier on 2wd trucks, IMHO. I called Les Schwab about 1" spacers to put in the front, then I want to remove the 1" spacers between the springs and axle in the rear. I noticed the pre '98 2wd Rams have no spacers. Les Schwab only carries a 2" front coil spring spacer, which is more than I want to lift it.
Does anyone know of a leveling kit or source for spacers that come in a variety of sizes?
Thanks,
Vaughn
2001 ETH/DEE, QC Shorty 2wd
Vaughn, I just lowered the rearend 2" by changing the shackles which cost me about $65. Now the truck is level and a little easier for wife to get in back.
2001 2500 4x2 Auto, Combo EFT/Boost Guage. Paint matched bed cover
George,
I hadn't though of the shackles. Where did you pick them up at? Sounds like the easiest solution.
Another consideration: did you have to re-aim your headlights? Anyone know how to do this? They'll probably be pointed up too high after dropping the rear 2". Also, I'll have to adjust/shorten the rod for the rear ABS height sensor.
Vaughn
