I have tried everything I can think of so I need some ideas. Here is my problem and what I have done: Truck has the EGR front package on it. Did this 3yrs ago. Truck was fine till about 5/05. It started pulling to the right (just when brakes are applied - runs straight otherwise). I called EGR and they sent new calipers (left and right) this fixed the problem. Also put stainless wrapped brake lines on front and rear. About 3 weeks ago it started pulling to the right again. Caliper pins have been lubed and are free. EGR sent a right caliper. Still pulls. I changed the pads around (left on right - right on left) still pulls right. Pads and rotors are 3yrs old but apear fine. I bought a pressure kit, both sides have 1100 lbs pressure. Rear brakes checked and adjusted. Still pulls. Front end was checked, ball joints, control arms, everything, no problems found, Still pulls. Track bar and steering box was replaced about 2yrs ago. I had all my work checked by a local shop to make sure I did not miss anything. It still pulls to right only when brakes are applied.
I have a summer and winter set of tires. Sine this started I have put the winter set on and it did not change anything.
What should I do next?
Ron
Ron
