I just replaced my right headlight due to the leak that repeatedly allowed it to fill up with about a half inch of water. The harness connector had lots of algae on it so apparently water was seeping out around the headlight connector. I cleaned it up with alcohol and it all looked good. When I checked the lights after installation everything, including the turn signal, worked. Now the right front turn signal doesn't work on lockup flash, turning indicator or hazard flasher. The right rear works normally except for the rapid flash due to the front not working.
I don't see a fuse in the fuse table. There is one for the right turn/stop under trailer tow, but nothing for the truck itself, at least nothing dedicated to the right front.
I'll pull the headlight tomorrow and check the connector for corrosion. Can anyone give me the pinout for the connector? Any ideas about what this might be if not corrosion?
Thanks,
Al
Thanks,
Al
