right pull count
Check this Cummins Engine out.
what temp.is gauge reading?
I would like to know how many trucks have the pull to the right! My hand-dandy Dodge dealer said "that my truck is the only one"?
Please stand up and be counted. I need information to give them!
ps. the spec's I want them to align to "they cannot do it".
Frank
01 White, Quad Cab,Short Box ,Sport SLT+,5 speed,4X4,line-x ,Nerf bars,fiberglass tonneau cover
Mine pulls also,not alot just enough to annoy me,its supposed to be within specs also. Its out of the basic warranty now so I'll be taking it to a good alignment shop soon. Don't trust any of the dealers around here to do it right.
2001 2WD Quad Cab SLT 3. 54 Tow and Camper package, short bed
May seem like a dumb answer but does it pull more in the right hand lane of a highway than the left? A lot of roads (especially CO) have a considerable grade crown for rain run off to the right.
Are we talking pulling to the right while braking? or all the time?
Mine goes straight as can be while driving, but hit the brakes and it pulls to the RS. To correct the problem, I will do a couple panic stops, and its better for a week or so.
The other week I changed a couple brake pads and the problem went away. (for now)
(NOTE: My truck wears the RF Inner pad faster then the others, so I have 2 sets, and keep changing the pads around until I get one set that is worn the same on all pads, then return them for the Performance Friction Carbon Matalic life time warrantee)
  • 98 ISB,QC,5spd,2wd,3:54lsd. Stock with Gauges!
  • 2000 Terry 305G 5th wheel
Guess they put my truck together backwards, because it pulls to the left. Been in for an alignment 2 times and no fix yet.
-Vic
99 QC 2wd 6spd
I have found that if I have a pull, and the alignment is correct, try to rotate the front tires left to right, and the pull will go away.
  • 98 ISB,QC,5spd,2wd,3:54lsd. Stock with Gauges! (and BD brake this weekend)
Mine pulls right just enough that I have to keep pressure on the steering wheel. I don't notice any pull while braking.
Cody Hale
01. 5 2500, QC, 4x4,Auto
Gig'em Aggies!
Mine pulls to the right on braking, no pull any other time.
96 CC 4X4 2500 SLT AUTO transmission, PrimeLoc, ISSPRO EGT Boost transmission Temp, GUTTED CAT, 150,000+ Miles still goin' strong, Lots of Ham Radio gear, NO IGNITION NOISE!!! Love my diesel!!! TST Fuel plate on the way, BOMBS AWAY!!!
Constant right pull. Right pull under braking when you really don't need it. My brake pull does not happen all the time.
99 2500 QC Auto 4X4
Amsoil Dealer
I had a 98 1/2 that pulled to the right. It was "fixed" 7 times. The problem would go away for a while then come back. It would start gradually and then get worse as time went on. I went to arbitration and that is why I now have a 2000 with the new front breaks.
2000 Dodge Cummins Diesel
6 sp manual, every option except automatic and sports package!! SnugTop Shell and Professional FireFighter License Plates. (To match my Flame Red Truck of course!!)
