Had a bad overheat situation on my 2001 and Pulled it apart, alot of crud (winter leftovers) around the rear caliper. Cleaned everything up(both sides, and put on new rotors and pads) and lubed the slide bolts and took it out for a test. It took about 25 miles to get it to heat up, and although it wasn't as hot as it was Friday it did get warm to the touch.
I guess its time for new calipers, I think it is a sticking piston, since only one side is causing a problem. I undertstand this is a problem in this part of the world (Ohio).
Is there anything else I need to look at before I order calipers? They are not real bad $ after market so I will do both sides.
Is there any tricks in bleeding these new brake systems?
Any suggestions would be appreciated.
Denny
Denny
