2001 HO, 6 speed, disc brake rearend.
I get home the other night and smell something burning, walk around the truck and the right rear wheel smells and feels hot, get out the temp gun and sure enough the right rear rotor is 470 degrees, left rear rotor is 98 degrees.
Background, wheel seals failed last summer, replaced seals, rotors, pads, and parking brake shoes. No issues till this week.
Here is what I have done to troubleshoot so far.
1. Immediately jacked up the truck without moving it, pulled the wheels, axles spin freely, no excessivie drag.
2. Thought it might be the parking brake so did not use the parking brake for two days, 1st day was fine, second evening when I got home, rotor hot again. Rotor was hotter at the outside edge than the inside edge which would indicate something other than the parking brake pads, if it were the parking brake the center should be hotter.
3. Today, had to set the parking brake twice before coming to work, no affect on the temp of the rotor so it leads me to believe it is not the parking brake.
A friend suggested a possible proportioning valve malfunction thinking it may not be letting fluid pass both directions through it, but they usually limit fluid going to the caliper in the event of a leak, I've never heard of one failing either.
Right now I am leaning toward a piston hanging in the caliper or ?
