Others have said it "love the truck, hate the electrical!"
It was about a week ago, I walked up to the rear of my 2004 and found the right rear turn signal burning brightly. The keys were in my pocket, the rest of the lights were out. When I used the right turn signal, the right front would flash fast but no change in the brightness in the right rear turn signal. I still have standard bulbs in the truck, no LEDs .
I pulled the left tail light assembly and swapped it with the right one, same thing, right turn signal burning brightly.
I removed the right turn signal bulb to keep from draining the battery during the evenings, but I hate to travel without turn signals on one side.
I've looked through the schematics for the turn signal paths, and much of my troubleshooting is pointing to the FCM.
I'm nearly certain (but that's why I'm asking for help) that the PDC is not the issue... While trying to solve a front left headlight issue last year (but that's a different thread), I had the PDC apart and have a ton of pictures of whats inside if anyone would like to see a relatively pristine circuit board because that's all the PDC appears to be aside from the soldered on relays for the trailer turn signals on it, and connections for fuses/relays. Oh, I had to bypass those trailer turn signal relays a couple of years ago, due to the one that controls the right rear trailer turn signal to stay on all the time as well but that's a different thread.
If I read the schematic correctly, the FCM sends a hot and not a ground to make the bulb flash. Let me know if I missed something there.
I'm suspecting the FCM is somehow sending the wrong information out, telling the system (itself?) that there is a bulb out in the right turn signal side, causing the right front to flash fast and at the same time turning the right rear turn bulb on and leaving it on.
I'm hunting for ideas for things to check before I spring for a new FCM. Have I overlooked something obvious?
Thanks for your help!
GF
GF
