Rims and Tires
cruise control switch
First Gen National Meet-up At Cummins Engine Plant
I'm looking at a set of:
Raceline 887 Rockcrusher 680-080 16x8 8x165.1(6.5")
Pairing these rims with:
BFG KO2 265/75 R16
Anyone have experience with puttng an 8" rim on these trucks with that tire size? Clearance issues? Etc? Thanks to any who respond
You shouldn't have any issues--that tire's virtually the same height as stock and only an inch wider, but balance weight clearance on the inside should be checked. My 16x8 are slightly different offset and backspace (about 1/4 inch) and run 305/70R16 about 1.5" taller, close to 2" wider, which required a tiny bit of front fender trimming at the lower corners, and mounting the weights on the inside lip.
Thank you for the info!
