So I'm looking at the break in procedure for new rings... and the package says to not idle the engine for over 5 min at any one time in the first 200 miles.... and to run the engine at 75-100% load for the first 75-100 miles and not to exceed 2000 rpm.... so I interpret that, if I tow, to connect a trailer and tow for those miles...
On the other hand the break in procedure for the cam shaft is almost the opposite, making sure that cam lube is used and of course to prime the oil system before the first start up... and then to not excessively load the engine but to run it through the rpm range....
Honestly I understand the idle issue.... and I understand the excessive rpm.. and it makes sense to me to run the engine through the rpm range... its doesn't make sense to load the engine for the first 100 miles to break in the rings....
I would be interesting to hear your thoughts...
