Engine/Transmission (1998.5 - 2002) Ring Sensor ???
Engine/Transmission (1994 - 1998) erratic oil pressure gauge
Engine/Transmission (1994 - 1998) heavy soot at idle
Code P0336 - Crank Sensor. Called the local Cummins Shop, counter guy told me Ring Sensor is what they have, says it goes in side of block about half way back??? Got the part number - 4002066, priced @ $43. 34.
Does this sound right?
The 99 manual calls it CKP for short, it is located below and to the rear of the fuel filter, have to remove the starter to access it. bg
Thanks. I wasn't aware of what the manual called it but, knew it's location and such. I was wondering if anyone ever heard it refered to as the "Ring Sensor"? and if the part numbers was correct for what we call the "Crank Sensor" and if the price is about right. Sometimes it's all about what someone calls a part that makes the difference.
I'll look in the manual later on. Thanks again.
Just found an older post mentioning same part number I refered to earlier, it the correct one.
ring sensor
Had the same code on my '03 5. 9. The sensor is just behind the dampner and should be covered with your power train warrenty. After they relaced mine it made all the difference in the world.
CMaster - Thanks for the reply. Im a 99 @ 134k and as we say "I am my own warrenty station". Hope your 03 treats you as good as my 99 has.
