Chris
Originally posted by illflem
Why do you want to run your boost so high?
Originally posted by Cummins Corvette
What snow man said. The ksb1 is ridiculously expensive for what it does. I would bet the same amount of money as the b1 costs that I am still hitting over 2000 degrees easy. The pyro gets pegged so fast it's not even funny. I've got the slowest pyro too: Dipricol. It hits 1500 just as fast as that little needle can move. I'm not saying that any other turbo is better because this is the only one I have tried other than the stock one. I can say that I saw no change in how fast I can peg it when I swapped turbos though. All I have gotten so far with the B1 is more lag. At least it hasn't broken yet.It has had a very small amount of sand go through it already. I had a guy from a turbo shop look at it and he said that it was just fine though. I want my hx 35 back. :{ I liked that one better.
Cooker: The stock muffler was the reason I haven't posted anything about the b1 so far. I have kept the stock muffler so long because I was afraid of making it louder, but this isn't too bad. I might end up adding another one if I want it to be whisper quiet again. If the B1 offers a 400-degree egt drop, then I must have been hitting something like 3000 degrees before. The only real test I have done so far is seeing how fast I can go up Parley's canyon at 1300 degrees. Before the b1 I could go almost 100, now I can only go 90. Oh well. Hopefully it is just this cruddy pump.
