Roadmaster Active Suspension
370 Diamond B
Killer dowel pin on the move!
Swayse
Will the Roadmaster Active Suspension raise the rear ride height any? I'm getting ready to lower the back end about an inch or so and put on the Roadmaster springs. I don't want to get the blocks shaved and get it all put together just to find out that the back end is back where it was.
I tried a front end lift to level it out, just too high for me.
I tried the Roadmasters last summer on my 3500 4x4. They wanted a test to see how they worked with a load, so I measured the height of the mudflaps with the camper on, then once again measured them with the camper on and the roadmasters installed. Adjusted as per the specs given us for the load, the flaps were higher than before.
I did not try this without the camper, cause my concern was to see if the roadmaster system would work with it.
