Roadmaster suspension - I'm impressed
Over the rail spray in liner with camper shell
Oil Analysis results, 22,500 on oil.
Picked the kit at MM and just installed this morning. First impressions are great, much better ride and handling.
Installation was straight forward, nothing tricky, just a lot of nut turning, an impact wrench would make the job much easier. Floorjack, jackstands, 13/16 socket, 2 3/4" open end wrenches, 3/8 allen.
Tip, keep jack under axle and compressing spring when taking U bolts off. Overload springs just lift off, keep spacers and the original U bolts will work. Took me about 3 hours, 2nd time with impact wrench would be about 1 hour.
I'm looking forward to towing with this setup, I think it will be excellent based on how it works so far.
Tom
Tom W in Austin Tx 98 24v 2500 Quadcab, auto, 3. 54, lsd, Rhino, white/driftwood, Banks Stinger Plus, 275 injectors, Manix grill, nerf bars , DTT's TC, valvebody, cooler, Smartbox, Mag-hytec trans & diff, Pac brake, Bilsteins.
[This message has been edited by Tom W (edited 05-25-2001). ]
Thanks for the review - I have a set in the garage I haven't gotten to yet - good to hear the install was straight forward!
