Roadmaster Suspension Installation Questions
Jacob's brake...need help
2 Wheel Low Kit
I have searched and sent a private message to TomW regarding his install, but wanted to open it up to the crowd...
I'm installing the roadmasters tomorrow and was hoping someone could give me a little more detail about the install.
1) Do you support the weight of the truck on the frame and then let the axle hang?
2) What about that nut in the middle of the spring pack... will the threaded part not stick up too far after you remove the overloads?
3) What keeps the axle aligned when you remove the U bolts? It would seem easy to pull (or push) the axle forward or rearward enough to be out of alignment, no?
Thanks!
Do you have a fax? I can fax the directions to you.
If not I can type a breif summary for you (I have to got get my scanner fixed).
-Ryan
