Engine/Transmission (1998.5 - 2002) Rocker arm and shaft galling
Hello, I was inspecting my rocker assemblies before putting them back on after installing head studs and found galling on all of them. Looking at the rocker arms from the push tube end it is always on the left side except for the two worst that have a little on the right side also. The shaft in the picture is the worst.
75,000 miles on engine, oil changed 5000-7500 depending on what I have been doing with it. Oil pressure is the same as it was new, other than a fuel injection pump no one has been into the engine.
Does anyone make a roller rocker for these or one that works better if this is a known problem? I can't see putting the same thing back on if the same thing is going to happen.
Thanks, Randy
