rocker arm stand bolt torque
Bhaf
G-tech ad NEEDMOPOWR's truck
Hope this helps, I checked a Hanes Manual and this is how it reads, For the 12 mm bots use the cylinder head torque specs which is
Step 1, all bolts 66 ft lbs
Step 2, long bolts 89 ft lbs
Step 3, turn an additional 90 degrees
I read further and it says that the 12mm are the long bolts, The sequence for tightening is from the front of the engine;
4th cylinder first
3 second
5 third
2 fourth
6 fifth
1 last or sixth
The small 8mm bolts get torqued to 216 in lbs (no sequence for these), Valve covers the same as 8mm's, If you need any more or want a scanned or faxed copy of this part of the manual let me know, good luck :)
