A must do for most of us older trucks!
Thanks for the "Rollover Valve" suggestions "Cooker"! You should not have any "wosh", presure, or vaccum build in our older 12V (maybe not even the newer 24V).
I run an axillary tank and it is been transferring slower and slower the last year or so (gravity feed). I thought mine was gaining presure but it is most likely vaccum like you stated.
I picked up a new valve from Dodge ($24) and rubber grommet. I tried to replace mine but found the factory valve up tight against the box crossmember. I have a longbox Excab if that matters. I had a full fuel tank and could not get enough room by just loosening the tank straps.
Here is what I found if you want to check your valve. The valve has a small hose barb that is exposed. I could not blow into the new valve very easy (tank vaccum) but could suck very easy (tank pressured up). I put a short rubber hose on my original valve and could not blow or suck anything... . Valve Failed!
jjw
ND
