MarkEagleUSA
My 03 QC leaks from the sun visor hooks every time it rains. Also, the floor under the rear seats is damp to the touch. When I first got it in March and discovered the leak my first thought was the cab lights so I went out and got some clear silicone and re-sealed all the gaskets and screw holes. It certainly made a difference but I still have the leak. All I can think of is there must be some sort of crack in one or more of the lenses. Unless there's another place water can get in up there? I checked the 3rd brake light and everything appears dry up there. I've seen where the newer trucks have a problem with the rear window leaking which may be my rear floor issue but that doesn't answer why it leaks from the visor hooks. Is there any other place where water can get in under the headliner?
