I'm hoping someone who has injection pump overhaul experience can help me. I've got a 1959 Ford 871D Tractor with a Roosa Master DM pump. I bought it not running with a bad crank. The engine work is done and I tried starting it. No fuel. I took apart the pump and found the plungers in the rotor to be lightly stuck. I was able to get them loose with a small pick. I checked the plungers and bore for corrosion, and all looks good. The plungers move freely now and hold air pressure for several minutes. When I install the pump it bleeds quickly and squirts fuel freely at the injection lines but still won't pop the injectors (they pop test fine). I've had the pump apart 7 times and I don't see anything wrong with it.
Could the plungers leak fuel under pressure even when they hold air pressure fine?
Is there something else I'm missing?
I've heard that these old roosa masters are very intolerant of water and contamination, but I definitely don't see any damage inside.
Any help appreciated.
Joe
Joe
