I installed one of these kits in my '97 2500 4x4 a while back and am very pleased with its appearance and the way it fit.
Recently I installed a '98 and newer two piece kit in a friend's '01 2500 4x4. The right section fit and looked as I expected it to but the left section left something to be desired. I had to mount it lower than I thought I should just to ensure that the screw in the upper right corner had some backing for its screw nearby. Had I mounted it the way I thought I should, I would have had 1/2" to 3/4" of space under the upper right corner and I'm pretty sure flexing the panel this much would have made the panel pull through that little screw.
I emailed Geno's but got my message back with a note telling me that it was "undeliverable" and that the error causing the problem was "permanent". I'm not done trying to contact Geno's directly but I'd be interested if anyone else has encountered the same situation.
