Rostra Seat Heater w/OEM switch
The FIRST RAM
Seat upgrade options
lionrampant
I've recently replaced my front seats ('06 Laramie) with a set of 4th Gen ('17 Laramie). As the '17 seat heaters won't interface with the '06, I've installed a Rostra seat heater. I'd like to wire it to run off the OEM switch, if that is possible. Has anybody done this, if so, how? Do you know if this is even possible? Any info would be appreciated.
Thanks,
Ken
Not possible, we tried everything to make it happen.
The OEM heater uses in-seat temperature probes to regulate the desired heat, where the Rostra just set the elments in serial or parallel to make the 2 step.
I replaced the dashboard part with one from a non heated car to make the useleß Knobs disappear.
Thanks, I though that might be the case.
-Ken
