Rotella antifreeze
where to set timing at ???
4" stock mufler inlet?
Anyone out there ever used Rotella 50/50 premix antifreeze. Says it's for Cummins diesel.
98 2500 club cab 4x4 12v 410 rear, tow pkg, linex, ARE utility top, unbombed to the max
That and the ShellZone are pretty much the same stuff. Just make sure you test your coolant often or do regular interval draining to ensure it's not becoming slightly acidic. Fleetguard sells a test kit and an additive to bring the coolant back to spec. Its Diesel Coolant Additive (DCA) is worth the money and available at all Cummins Dealers.
Chris Timochko
1997 5sp 4X4, HX40, BD 4" Brake, Marine Compression, Custom Tuned Injection Pump, 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, Water Injection, NOS Diesel Kit, 6" Chrome Exhaust System, No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. Test mule for Auto Wurks Diesel race program
