I have at least 1 rotor warped. I think excessive heat has caused this since I suspect my calipers are not releasing entirely. Last set of pads only lasted 13k miles. I have a rebuild kit for the calipers and once done with that need to deal with the rotors.
Both rotors have been turned now twice. Can they be cut again and would this now accelerate further warpage due to the thinning disc? I could not locate the minimum thickness stamp on the outside of the rotor.
I'm leaning to just replacing the rotors this time around. I've read both the good and bad on pulling these things off without damaging the axle seal.
Any thoughts welcomed of those that have been down this path.
ic
ic
