It's been idling very rough until warmed up as the temps fall this year, never used to do that. Always started and ran great, even very cold.
Went to start wed. morning, on my way to the airport (of course), and the GFI musta tripped, 'cause the led on the plugin wasn't lit. Well it started, 'bout 3rd or 4th compression, but ran really rough. Jammed a 2x4 onto the pedal for a fast idle and went inside to get my stuff. When I came out, it was dead, and would not start. Good cranking power, but not even a hint of firing. As I was gonna be late for the plane to go to work, I had my wife drive me instead, so it sits at home, waiting for me to get back and fix.
Been reading and searching, and sounds like I need to check; fuel filter, KSB, FSS, Grid heaters (pretty sure they're ok, but will check), fuel heater.
Now, lots of you seem to think it should start fine without any of this stuff, down to below zero (it's only about 10 F). So I'm thinking either FSS or gel (I have been adding stanadyne). But what about the rough idle when cold? I'm still thinking KSB on that...
What else am I not smart enough to ask?
Before you ask, I need a new fuel filter. It has 0W40 synth in the crankcase. Good battery. Pretty sure the grid heaters are working.
John
John
