Hello, my ram 3500 has 281K miles, i have replaced the FCA in an attempt to remedy the problem, no luck there. I then checked the codes ( i know... backwards) using the ignition key / digital readout and found P0839 and P0483. The 0483 might be related to my AC not working last week, since fixed. From what i can tell the 0839 is supposed to be for the 4 wheel drive switch...but the odd part is my truck is now and has always been a 2 wheel drive??? So my two questions are:
1. what gives with the 4 wheel drive code in a 2 wheel drive truck?
2. what else should i check in an attempt to remedy my rough idle?
Any help would be greatly appreciated,
Rick
Rick
