Ok I am new to the site, had a long member friend tell me I had to join cuz I could find help here.
So I have a 1998. 5 24valve with about 430,000+ miles. Starting around the beginning of winter I had a slight small skip, nothing major barely even noticeable, as winter went on and we are now pushing through spring it has gotten way worse and is a really rough idle, and NOW beginning about 2 weeks ago it wants to idle about 1300 rpms after it gets warm while still sounding rough. But when you put it into drive or reverse and put the load on it then it sounds fine, unless you go to coast then you can hear it running rough, and with the idle wanting to run high makes it hard to brake and slow the truck down.
Here is a quick low down to what i have done, I changed the injectors and checked the valve lash about a week and a half ago thinking that might have been it but didn't change the way it ran. The injection pump was changed about 2 years ago with 20,000-25,000 mile on it. It doesn't have any lack of power and pulls hard with the new injectors, I have check fuel pressure and its an all stock system with the in tank pump, just checked the pressure today, 7psi at idle, and 5. 5-6psi while cruising, and 3psi at wot, which I heard isn't great but still kinda okay. Also I run WMO, I have been running it since August of 2012, never run more than a 50/50 blend, in winter I switched to 70/30 blend 70%kero/30%wmo, and I have now switched back to a 60/40 blend 60%#2/40%wmo, I have even ran a few tanks of pump diesel to check and see if that makes a difference, and there is none, I also have NO codes, has a good friend mechanic use his Snap-on motus to check and make sure there was defiantly no codes, and nothing.
Oh also changed out the ECM with another buddies to check to make sure it wasnt ecm and still runs rough at idle so it can't be ecm.
Please I would like some more help or ideas, no one here local has an idea, mechanics don't know nothing unless its got a code... please help, thanks in advance
