Trying to help out a friend
He has a 2002, 24-valve, auto transmission, old edge chip not prgramable and low pressure fuel indicater lite that come on if below 9 psi. which it never did.
When he first started it up yesterday it started running real rough bucking etc. , check engine came on then it raced to red line & quit. Said it sounded like it was going to blow up. He restarted it ran ok went about 100 miles engine light on shut it down restarted engine light went out. Seems to run fine at present. He has had an ongoing problem with it running rough on occation but never to this extent. He has had mechanics look at it & changed fuel filters etc. to no avail.
I would appreciate it if someone could give us some ideas on where to start.
thank you
PS. He had the factory lift pump go out while driving through Dalls Ore. 2 years ago. They replaced it with the same type.
thank you
