What do you think about a forum that would contain routiene maintenance procedures?
Example:
I bled my brakes yesterday. I have a very simple procedure to do that. I thought, the way I do it might make it easier for someone else, I wonder if there is a way to post my procedure so others could read it and not in the regular forum discussion location.
Routiene things:
How to: XXX (change oil, filters, change brake pads, bleed brakes, change power steering fluid, radiator fluid, differential fluid, Vp44 exchange, Intecooler boot exchange, fix the fuel level rheostat, etc.
I know there are threads after threads on the main forums on these subjects, but collecting them into a single "how to" place might reduce the main forum size some, hold the redundancy of reitterating threads that already explain it, and still would have the knowledge base in a single place easily accessable.
Maybe there is already a place that I just do not know where.
Probably by generations, then by engine like you do now, then by system affected.
Ideas?
Bob Weis
Example:
Routiene things:
Ideas?
Bob Weis
