I just dug up this post from 3-1-05 concerning running royal purple in your transmission and the conflicts with the dealer that it creates. Will the dealer void my warranty if I run RP ATF max in my transmission. Here is the post I found. Thanks for any help.
This is a an email I got from Royal Purple concerning their ATF fluid. I think it is really ridiculous to not let anyone else manufacture a comparable product. When my warranty runs out I will definately change!
Brad Chesley
Brad
While your truck is covered under warranty I recommend using the ATF=4 transmission fluid. At this time Royal Purple is not offering a replacement fluid for the ATF+4 that Dodge will allow the use of while under warranty. In fact I don’t know of any aftermarket fluid that Dodge will allow you to use under warranty in that transmission.
Now after your warranty has expired you can use Max ATF with no problem.
Brad Chesley
Brad
