I had a 70 dodge 3/4 ton truck that I installed a 440 with a steel crank, TRW forged pistons, bushed adjustable rockers, good rod bolts, and a lot of other things also. For a tow truck it was fun to drive. I gave it to my son and he would drag race it. He told me that he put in on a 454 ss truck.
I ran 15-50 mistic and I never had a bit of trouble with it. I did not use full groved mains as the crank was cross drilled. You would be supprised to see the different ideas as far as fully groved and not fully groved bearings and oil pump volume requirments and how reccomends them. GM and Dodge.
I use to turn my 80 camaro from 4k to 6. 5k for hours on end and never a problem. A 68 camaro 302 engine that was also my street car and I had the rev limet set a 8k and that is with steel rods. It was a sprint car bottom end with a special set of cylinder heads at the time and a 600 isky roller camshaft and related parts. There is few things that gave me that kind of thrill as to hear and fell a engine pull to 8k hard.
I never had a bit of trouble with the engine and it used 15-50 mistic. I dont wont to think about it to much as that stuff is had to stop once you start. Jim K
