Upon startup my truck's rpm will flair up to about 1800 RPM's for just a split second and then back to normal idle. It does this about once out of every 7 starts. When it first started doing this it only happened about once a month but steadily has got worse. I disconnected the batteries for about an hour, cleaned the posts, disconnected and put dielectric grease on the APPS connection and the injection pump connection. I recalibrated the APPS after I hooked the batteries back up. The problem went away for about five days but then came back. The check engine light also comes on when it does this. I have an appointment to have the codes checked on Saturday but was wondering if anyone has had this problem or knows about this before I go to the dealer so I have something to contribute to the diagnosis. Unfortunately my truck was one of the early ones that does not have the codes show up in the instrument panel.
Thank You,
Ron
Thank You,
Ron
